Apple
- Oct 17, 2010
1996
200
I have a 1996 explorer with 4x4 with the 4.0 and auto tranny,261,000 miles (I think its the 4r44e but not sure). Last year the torque converter started to unlock and lock back up right away about 3-4 times each way in a 17 mile drive to work. About 2weeks ago my wife took it to town and on her way home it quit going into overdrive. I took it out the next morning for a drive around the block and it shifted up thru the gears fine, but no overdrive, the O/D light was flashing the whole time. When slowing down it had one hard down shift and the others were normal. At the next corner just as I let off to slow down it shifted into overdrive and downshifted normally coming to the corner. I stopped and checked the codes and (I can't remember the code number right now) but said Input turbine speed sensor circuit. I cleared the codes and started driving again. The O/D light was off but it was just slamming into the next gear really hard at a slow speed and after about 30 yards of driving the O/D light started flashing again and shifted normally from 2-3 but would not shift into overdrive again. I was going to replace the epc solenoid but they are $385.00 thru Transtar, and thats alot of money if I am wrong. The input speed sensor would be a tear down on the tranny. Any help would be great. I really need to get this back on the road. I have found another trans for $525 Would that be the better way to go? Or does this sound like it is the epc solenoid?
