97 ranger 3.0L 5spd 4wd. 165k miles
going on 26 working hours on this thing trying to get the clutch working properly after replacing the clutch kit and slave cylinder. it is driving me CRAZY
i think i can say i've tried almost every bleed technique except reverse injection.
bench bled the master cyl 3 times, tried vacuum bleeding, gravity bleeding, pumping the pedal and cracking the bleeder, lifting both ends of the truck, having a bleeder hose submerged in brake fluid while pumping the pedal, tried pushing the slave cyl piston back with a pry bar and then opening the bleeder. i've probably tried a couple other things too
i verified the master cyl and line is bled by checking piston travel before reconnecting the line. after bleeding the clutch the pedal feels BETTER than my ranger which works just fine.
after bleeding i checked the slave cylinder travel.. 8mm of travel. specification is 7.5mm minimum so that must mean the clutch is bled properly
i've tried 3 pressure plates so far, 2 non adjusting and 1 adjusting.
pilot bearing isn't hanging up, sanded input shaft clean just to be sure
my boss is cheap so we didn't resurface the flywheel, it looked ok. clutch might have been done before. pressure plate was LUK brand with a ford number on it.. is this OE? the replacements were LUK also.
the only thing i have left to think is to add shims to the flywheel or replace it, natually the boss man threw that idea out the window and wants me to waste even more time on this POS. if it comes back to the flywheel i've have to remove the transmission for the FOURTH time.
im basically out of ideas, about to ****ing quit due to this bullshit. i've wasted 3 days on this and im about to waste more time on it tomorrow.
if anyone has any suggestions i'd appreciate it
