Not sure what this is
Kingoverace
Solid Axle Swap
Jersey
Ive got this line running along the frame. It goes up to this part in the pic belowe the master cylinder. I dont know what it is. I believe the line runing along the frame to the air canister behind the gas tank, but i dont know. Its a 98 and had a 3.0. I just dropped the 4.0 in and am reconnecting everything. so if anyone know where the rubber hose i put on thop of this is sapposed to go, that would be helpeful too.
any idea where the rubber line went to on the 3.0? It comes from behind the IIRC
king u do know iirc isnt a part it stands for if i remember correctly
That big black plastic (crowned) part is your EGR vacuum control solenoid. It takes 2 small vacuum hoses: one is your (INPUT) vacuum source, and the other provides (OUTPUT) vacuum to the EGR valve. But that loose hose looks way too big for it.
