Not starting with key
Fixed it! CRANK SENSOR :yahoo:
glad you got it fixed .but for future members maybe you can fill us in in how much the part was and how tough the repair was..did you have to pull of the harmonic balancer? etc.
Sure! Crank Sensor $45 at local parts store. Lifetime warranty! I have the 91 4.0l V6. It was very simple. Two 10mm bolts by the crankshaft and it was changed. Less than a minute. This will vary depending on what engine you have and year. On some engines, you will have to remove the crank pulley and timing cover. Good Luck!!:headbang:
