Jetnjmy
- Dec 30, 2014
- Automatic
I have a 2001 Ranger 3L automatic. It has been running fine. The other day I tried to start it and it just cranked over. Pull hose of TB and squirted starting fluid and it fired right up - and continued to run just fine. I shut the truck off and tried to restart and it was all OK, ran fine. Tried it this morning and same problem. Cranks over but will not start. Again, I used starting fluid and all is good. I need to have the truck working correctly tomorrow. Does this truck have a check valve in the fuel system? I do not hear a primer pump activate with I turn the key on but I am baffled as to why it runs once it starts up and it will start again but not once it sits for a period of time. Suggestions?
