rm428
- Oct 7, 2012
new here and hoping someone can help solve a problem i'm having.
recently got a 89 b2, it had been sitting for the last 3 years with some use every so often, been driving it daily for a few weeks now. replaced the fuel filter, corrected the timing, replaced the clutch, plugs wires look to be in good shape but it's still running funny... when your low in the rpm's in any gear it stumbles, stick shakes doesn't have any power. when you first fire it up it has to warm up for at least 5 min or so and if you don't it jerks when you try to give it gas once the clutch is out. every now and then when you come to a stop the motor will stumble and sometimes complely die but starts right up.
any thoughts on what it might be or hoping someone had a simular problem what did you replace to fix it.
thank you
thank you
