Not only bypassed
coreyjdl
To anyone who is familiar with bypassing the heater hoses running to the intake plenum just behind the throttle body...
would running cool water through there be a terrible idea? I live in a fairly warm climate, and it wouldn't be to difficult to switch between warm coolant and cold coolant either way.
i have a small oil cooler and with a 12v pump and a small homemade reservoir it could have its own cooling circuit.
the plenum gets pretty hot right now, just quite to hot to hold your hand on, but touchable w/o consequence.
Your engine was designed to operate properly at designed temperature range. I doubt you would gain anything with by-passing heater hoses, and you may cause poor performance if sensors pick up out of range signals.
