Not a ranger but need help 7.3
db796
Firefighter
EMT / Paramedic
missouri
This is not a ranger far from it but this being a site with some ford tech's on it maybe they could help... I have a 1999 7.3 powerstroke after making a sharp turn i lost power steering and brakes this must be something with the hydro boost but im not sure any ideas if you think you know what it could be would be great! however at about 2000rpm everything works right good power steering and brakes the power steering pump runs everything (hydro boost) Looked all around no leaks was dark out but with the flash light no pinches or ruptures The fluid is not circulating at a idle in the power steering reservoir.
Now do you mean just lost power brakes? Or are there no brakes as at all? Amy how check to make sure you power steering pump is full. From what I read they power steering pump is what also gives you power brakes. So if the pump dies/ is dry you wont get power steering/brakes.
