modular
- Dec 30, 2008
This is on a 1997/standard cab/shortbed/ 2WD 7.5 open rear end. At around 30 mph I start hearing an oscillating humming noise from the rear diff (humm-quite-humm-quite-humm). It is slow like it has something to do with the ring and pinion and does increase/decrease with my speed under acceleration and coasting and both in and out of gear. I put it up on jack stands, put it in 3rd gear and can duplicate the noise with no weight on the axle. It is coming from the diff and the noise resonates up through the bed. When I had my alignment done they did find a bunch of plastic wrapped around the u-joint at the rear diff. No leaks are present and it is stone quite until 30 mph and dissapears at about 55 mph. Is this the pinion bearing making noise? The truck has 81K on it. Thanks for any insight.
