RustedRanger
I put up a post yesterday about radio interference in 1st gear only. Today I cleaned the plug in for the condensor on the coil and checked the other plug-ins located in the same area and generaly just looked everything over and sprayed everything with WD-40 and now it wont run at all
It's cranking over fine and is getting gas but it seems no fire. I see one red wire going into a round connector that looks to be broken inside the insulation. I called my friend who does diagnostics and he said that might be it,he also said I could check continuity but my voltmeter is analog and could possibly send to much juice through the wire and fry something so it looks like Im stuck here until Monday evening till he can come and look at it
This is the first time it has refused to start since I got it
