- Aug 7, 2007
- Costa Mesa, CA
- State - Country
- CA - USA
- Other
- 2004 Bronco Badlands
- Vehicle
- Ford Ranger
- Drive
- 4WD
- 4.0 V6
- Total Lift
- 1.5"
- Tire Size
- 33"
Recently, the 2.9L 89 STX that I sold to a co-worker in 2002 would not fire after he shut it down. He told me he hit a hard bump not too long before he shut it down. The only thing I could think of was to check the fuel pump shut off reset. Well, that was not the problem so he had it towed to a mechanic for a full diagnostic. When they got it there they tried to start it and it fired right up. The diagnostic showed everything working perfectly with no codes.
A few weeks later it did it again at home. I think he said it would turn over just fine but would not fire. He does not know much about repairing vehicles but decided to look around in the engine compartment. For some reason he noticed two smaller wires, kind of hidden by the large wire, going to the positive battery terminal. He moved them and they seemed flimsy so he moved them a little more and they broke off. Apparently the many years of exposure to a small amount of battery acid corroded them. He figured out a way to repair the connections and tried to start it. It fired right up.
Hopefully he found the problem. My question is, what do those wires go to? Could either of them prevent the engine from firing?
