No speedo or shift
Ranger428
Ohio
1999 Ranger 2nd 3.0 will not shift and no speedo. Did ohm check from Vss to gem and is ok. Ohm wire from gem to pcm grey/black and was ok. Having truck in drive have .48 volts to over 1 while speeding up from VSS TO GEM. Could not find reman gem so bought used one same thing. What is the output on the gem grey/black wire? Does any company rebuild these gems? Thanks for any help!
Do you have a code for the speed sensor signal being missing to the engine computer?
Looks like there are two different ways they ran the speed sensor. A RABS system where the sensor goes straight into the GEM, and a 4RABS system where the speed sensor goes into the ABS module first.
