no spark
Ranger#1
lake havasu
:bawling:prob here no cel just fired it up and shut it down went to start again 10 sec later and no start and no spark coil restance is ok wtf =[ also have 12.7 v to the coil
coil tested out OK and so did the ignition control module only thing left is the ckp [crank sensor]
what other sensor if left out would cause a no spark situation
the ecu temperature sending unit mayby
pulled a code 22 thats it i didnt know my truck had a map
I don't think your truck has a map. My computer also has thrown that code at me and I know for a fact mine doesn't have a map either.
But I discovered the hard way that you can buy a map for a truck that doesn't have one. I ended up talking to the dealer to confirm mine did not have a map.
In any case if you arn't sure. talk to the guy selling the parts at the ford dealer.
yaaaaaaa i now have interminent spark and i had one loud ass backfire but not enough spark to fire it
i would say Crank position sensor unfortunately for $46 (at my AZ) it expensive if its not the problem and once installed most won't return
