Nicholas D
Another electrical issue, sorry, I've searched here but cannot find a definitive answer. Just like the title says, the turns signals (front and back) randomly stopped working but the hazards work fine, albeit, they seem to be flashing faster than they should, but I'm not 100% about that. I switched out the flasher relay with a new one and it didn't change anything. I've checked all the grounds that I know of, and they are all clean - I just scrubbed them all a year ago. All fuses are intact. I still need to check the bulb sockets but if that's not the case am I looking at a new turn signal arm?
Of note too, when the brakes are applied, the brake lights come on as they should, however, if the left signal is turned on the left brake light goes off. Same for the right, brake light on fine until the right signal is turned on, then the right brake light goes off.
Any help greatly appreciated!
