No Reverse Lights
schopen
Every time i put into reverse i blow the fuse. Pulled out reverse lamps on both sides and the fuse. I have continuity at "lamp harness'". Reading of 4.9 ohms. Changed out clutch and slave cylinder 3 mths ago, if that may have anything to do with it. Where should I start?
