BillRod
88 Ranger, 2.9L V6, 5speed Mitsubishi, 4x4, ext cab,
No power accessories, no air, no cruise.
No power to the front fuel pump.
-OBD1 reader shows code 95 "Fuel Pump Secondary Circuit Fault"
It also shows:
67 Neutral Pressure Switch
14 Engine RPM Sensor Fault (diesel)
29 Insufficient input from vehicle speed sensor.
- Ground is good as I put a meter from the battery post to the connector on the pump and there are Zero ohms of resistance.
- I also ohmed the engine and frame and a bunch of other places and ground seems to be ok everywhere except the pump connector.
- I probed the fuseable links coming off the solenoid and they appear ok.
- I used a jumper wire across the inertia switch.
- Fuse #18 for the Electric Fuel Pump Control is good.
What is a Neutral Pressure Switch?
I am familiar with the Neutral sensing switch on the trans.
That seems to work as the engine will only crank when the clutch is all the way down.
What is the Vehicle Speed Sensor?
The Chiltons states it is 1/2 way down the right side of the transmission assembly. But the only thing on either side of the tranny is the backup light switch.
Any thoughts?
It also shows:
Any thoughts?
