Jwill41
88 ranger 4 cyl 5 speed acts like no power to anything. No dash warning lights, no radio, no horn, etc.
All is good to solenoid. Can jump solenoid and motor spins as should but no fire.Remove and clean both battery cables and terminals
Follow each Battery cable and clean its connection to terminal and engine/body
On the inner fender is the Starter Relay(often called a solenoid), Battery Positive cable is connected to one larger post on this Relay
On that same post are several other wires
This post is the 12volt link for ALL power to the vehicle, so all wires here must be clean, this is where ignition switch gets its power, where ALL the fuses get their power
Use a Volt Meter/test light to make sure Battery voltage is present, at the battery and at end of battery cables
