No power, battery ok
rxturner
Hi,
My first forum and first post.
My '94 Ranger wouldn't start, just clicked. Replaced starter relay, reconnected the battery and no power to any system. No fuses blown or circut breakers tripped. I'm at a loss.
Welcome to TRS...
Check the ground wires...there is one to the starter motor and two or three on the front that go from the battery to the front frame...and check that the terminals are tight...try wiggling them on both the + and - posts and if they are even slightly loose...tighten them up...but make sure to have a spare or two in case they snap...
thanks
Mark,
Thanks for the advice, I'll give it a try.
You're welcome...let us know how it turns out or if you need further assistance...it's usually something simple...like a loose wire...
well a simple way to make sure you getting the ground to the block (where the starter is grounded to) is get a per of jumpers ground 1 to the battery & 1 to the block if you start it is the ground on the block. i just had this problem!
