lost86broncoii
- Jun 4, 2009
- Baldwinsville, NY
1986
199
Ok so the past month or so my 86 bii has been having a problem with the entire fuel system, i replaced the high pressure pump, the relays, and the fuel pressure regulator(about a year ago) i can hear humming and fuel move in the tank when i turn the key so i am assuming the in tank pump is good but i haven't double checked to make sure. so the problem is idle and start ups got a little rough then i notice a hesitastion in acceleration just when i was getting on it, now its gotten alot worse i can't get on the highway cause the truck won't accel enough, the rpms just surge like she loses fuel pressure, could the in tank pump be out and not pulling enough fuel for the high pressure to pump? i pulled the vaccum hose to the fpr and it had a faint gas odor, could it be a faulty one, i know i changed that regulator like three times in a row on my old bronco ii cause i kept running the tank dry(broke fuel gauge
) any input or help would be great i am thinking about trying another pressure regulator? any way to check the tank pump easily other than listening?
also i heard so grinding from my rear end the other day, not sure how that would or could affect my engine rpms but i figured i'd mention it any way, i sucked the old gear oil out with some small metal shavings and put new oil, but no track/slip-additives(wasn't sure if i needed it)
Thanks for the help
Thanks for the help
