So I will need to recalibrate the speedo if I put different size tires on. Correct?
Your speedometer calibration will be wrong if you change the tire diameter.So I will need to recalibrate the speedo if I put different size tires on. Correct?
For 1998 ~2000 Rangers, speedometer error can be corrected by using a dealer tool to access the GEM (RABS truck) or ABS module (4WABS truck). The PCM is not involved.
Limited speedometer corrections can be made in the PCM using a dealer tool in 2001+ Rangers. Larger corrections are possible with an aftermarket flash tuner.
An aftermarket flash programmer cannot make speedometer corrections for 2000 or earlier Rangers. The OP has a 98.Just go and buy a programmer and that will take care of you problem that way if you decide to change the diameter of tires again you'll be set
Hey, sorry, I dont mean to thread jack, but I've been curious about something. With bigger tires, if you dont recalibrate, does the Odometer read lower?
