DFracing
- Mar 14, 2009
- Automatic
hey guys, a while back i did my timing chains on my sohc, and had the heads rebuilt, at the same time i Put a camburg kit and 33's on it vs the stock 29's. Ever since then the truck has had about 1/2 the low end power it used to. I had just been assuming that it was because of the larger tires but, now im not so sure, the weird thing is, at about 3800k the truck wakes up and shoots off like a rocket, almost like vtec. Seriously, i would almost define it as turbo lag if i had a turbo. previously i could do 75 up a 6% grade loaded down with a 450 quad and a weekends worth of gear at the desert, for two people, in overdrive at 2400 rpms. (3.55 gears) now the damn thing bogs down, and has to down shift if it even looks at a hill doing 65 on the freeway. Is this because the taller and wider tires, or could there be an issue with my timing...........
air filter is clean, and there are no check engine lights, ive scanned the motor multiple times for a trouble code and have found nothing.
thanks in advance
thanks in advance
