kunar
Forum Staff Member
⭐Supporting Member
- Jun 10, 2003
- Toledo
- State - Country
- OH - USA
- Vehicle
- Ford Ranger
- Drive
- 2WD
Heater cores can be replaced very easily and if you go to a junkyard you can usually pick one up for less than $20...if you go the JY route, you also get to learn how to remove and install one without damaging your truck because you can't damage a wrecked truck in the JY...just handle the core with care and it should work fine for you...if you take it to a rad shop they can test it for you if you want to be sure, but that's not usually needed...
Good, easy learning without paying someone to do it for you...all you will probably need is a good screwdriver to remove the clamps and a bit of climbing under the dash...
you can get a new one for $20. removal and installation is nothing on these trucks. 5 screws and 2 hose clamps. i could do mine in 10 mins now that i know how.
and makg, where are you going on dates for $20??
