No head lights
flospot
I just got a 1988 ranger s.c. no head lights rear lights good
Fuse good all lights work but head lights: :bawling:
Could be a bad ground at the relay or a bad connector/wire somewhere. Look at everything, and see if it is damaged.
Nick
Sure the switch is still working correctly. If I am not mistaken you have to pull it out twice to make the headlights come on, once for parking.
Thks for your help
I found high beam switch not working
i have this same problem. all fuse are good. replaced the headlight switch... still no head lights. anyone know of a wiring diagram for the headlights?
