No ground on entire ignition system
Entity
So, long story short, my girlfriend's Ranger won't start. Ironically, the last time it started was when I tested the fuel pressure, which is good. It will hold pressure in the fuel system fine, so I had the entire ignition system tested. Not a single component leading clear back to the PCM has ground, but has power to it. I put a new PCM in to rule that out, and it still has no spark. The relay is clicking on fine, and I switched it out to be sure. Aside from torching it and dancing around the flames, I can't think of where to go next. Anyone with an idea, please send it my way! Thanks, all.
I apologize for my delay in responding... in the middle of a hectic move. I had it tested by a mechanic (20+ years experience) friend of mine. Didn't test any grounds from the PCM because, frankly, I wasn't sure where that'd be. Every other accessory works, just not the ignition system. Horn, radio, lights, etc.
Creating spark is done by grounding and ungrounding the 12v primary of the coil(s). The PCM switches this grounding on/off with inputs from crank sensor, etc. If there is no path to ground then the switching won't occur. You'll need a circuit diagram to locate PCM ground to test or use a jump wire to establish.
If you can locate the 12v primary lead to the coil(s) then you should be able to hook a test light to it to see the switching as you crank the engine.
