A/Cmark
- Jan 16, 2016
- Automatic
I have a 1998 ranger with a 4.0 .. I was driving home and out of the blue the truck seemed like it was running out of gas with a half TANK.
the fuel relay is fine , the inertia switch is made and has voltage .
I jacked up the bed and fed 12 volts to the pump and it worked.
I used piercing leeds and found the pump runs for a couple of seconds then power is cut. every time I turn on the key it powers the same time.
I thought the fuel pump sensor ( on pump assembly ) was bad replaced and truck is the same
I have a obd2 to usb interface but I don't know what I am looking for.
I used to work at a corvette shop, and now work with computer automated controls on refrigeration systems.
I just don't know what tell the ecm there is a need for fuel , or what may be acting in safety mode
PLEASE HELP
PLEASE HELP
