cmpcoolcat
I was coming back from a lunch break at work when my 92 2.3 shut off. would not restart and after some research i noticed that when the crank turned the cam did not. nor the timing belt. I have since torn it down and found that the teeth on the belt had been shredded at the bottom of the crank pulley. I have replaced the belt, lined up the pulleys and no spark. I am intending on a turbo swap in the near future but i have to get to work until then. I dont know where the cam sensor is or if that is the problem and I have seen something at the harmonic balancer that would appear to be a crank sensor but the parts store says that it doesnt have one so, i desperately need to get the spark back in this relationship so i can make it to work monday please help asap. thanx
