no feel in the clutch pedal
turboL
fairbanks alaska
so today i replaced the slave and master cylnder. i bled the system like 3 times, but i still have no clutch feel at all. i need help i cant drive it at all
Go to AutoZone and buy enough rubber vaccum line (a size that fits tightly around the bleeder nipple) to go from the slave cylinder to the reservoir.
Make sure the reservoir is full and have your assistant pump the pedal while the line is going from the bleeder screw into the reservoir of fluid. I use duct tape to hold the line in the reservoir. Open the bleeder screw while your assistant is pumping the pedal and leave it open.
Have him/her pump it about 5 times then tighten the screw and go fill the reservoir back up. This time have your assistant pump the pedal about 25 times while the bleeder screw is open and on the last pump have them hold the pedal down while you tighten the screw.
After a few times of the 25 pump routine you should be bled.
Allen
