CheapThrills
I had a CEL p0301, checked spark plugs, wires, coil, all have ~10k miles. Swapped the coil, and still was misfiring. So I read somewhere it said it could be injectors, and we had an extra set of injectors we sent out to get repaired/cleaned. So after replacing the injectors, the truck ran like shit, noticed a bunch of fuel leaking out, so I shut it off, hit the fuel shut off switch, and started taking it apart again. Fixed that, put it all back together, and it went to crank and then stopped, now it wont even crank over. I noticed fuel all around the exhaust where there are welds.. Could I have bent a piston rod? I've never really dealt with this type of problem.. All help I've received, and still receiving is greatly appreciated.
