mred3
Hello I have a 2005 Ranger with a 4.0 sohc that all of a sudden started running real rough, got it home and tested it, OBD was giving me a cyl #1 misfire code, after diagnosing, it came out to be no compression whatsoever on #1 after this I decided to hook up the air compressor to the cylinder with both valves closed and air was coming out of intake side, so then I took the intake lifter out and retested with air into cylinder and no air was coming through intake then I checked the lifter it was very hard to compress in fact had to put vise to accomplish this. Bought a couple new lifters and install the intake one thinking this would fix issue for sure, but still no compression from the cylinder, the cam follower looks good, valve spring looks good/intact so what heck could this be never heard of a intake valve being burnt.
Thanks
Ed
Thanks
Ed
