TRH
- Aug 12, 2009
- '89
Honest, I like my 2.9. And I love my truck.
But I feel like I should have just a little bit more get-up-and-go than being totally unable to accelerate after about the 55 mark without going down a hill or holding it to the floor for a long period of time. It doesn't even rev above 2,000 in 5th gear..
I've put a good bit of work into the truck before it even hit the road. New U-Joints on the rear driveshaft, sparkies, distributor, cap, rotor (distributor was damaged, ouchy!), 180f thermostat, electric fan.. nearly the entire rear suspension. U-bolts, plates, springs, brackets, shackles, bushings, shackle bolts, brakelines, shocks, shoes & hardware, adjusters, e-brake cables galore.
Everything I "fixed" turned out great..
But the truck acts like it has no balls.. I seem to have a steady 17 vacuum that drops a little then jumps when revved (seems right?). It idles a little shakily even having set it at 12BTDC, going to attempt adjusting that and replacing mounts (as they're a bit squashed). K&N stock air filter.
1-2 and 2-3 shifts are fine. But after 3rd, it's pretty tough to get over 45. Once it hits 55, it's basically impossible to accelerate anymore. The cable seems a little slacked off on the pedal, is it possible it's not opening all the way? Any good method of checking this?
Fuel pressure is right on par and it has a new filter on it. The Fram that was on it was full of goo, but I checked the new one after a few days and it's OK. I have had the upper intake off and cleaned the IAC and stuff while I was at it, replaced all the gaskets and stuff.
If the 2.9l really is that weak, I guess I have little choice but to adapt and overcome with my M5R1 and get a 4.0L in this thing to start hustling a little more. If you guys have some suggestions for problems to look for or things to swap and wiggle with before changing motors, I'd really appreciate it. I don't really have the time or money to invest in that major of a change right now, so I'd just like to be able to drive on the thruway.
