NHmike
Anyone here from NH and/or familar with the laws regaurding suspension? I've seen some info regarding laws against altered frame (step notch), but is there away around this? For exampe is there a way to register the truck as a custom, or hot rod? I found this :
PART Saf-C 3202 DEFINITIONS
Saf-C 3202.04 “Homemade vehicle” means a vehicle made from various parts of other vehicles so that the serial number of the body frame does not reflect the vehicle’s identity. The term includes “composite vehicle”, “reconstructed vehicle” and “kit car”.
Saf-C 3244.14 Vehicle Body or Chassis.
(b) Welded frames shall be permitted as long as any joints have the equivalent strength of the original frame and the alignment of chassis parts is not affected.
(c) Lap joint welds shall be permitted as long as the joints have the equivalent strength of the original frame.
Refering to the definiton of “Homemade vehicle means a vehicle made from various parts of other vehicles so that the serial number of the body frame does not reflect the vehicle’s identity". Does that mean if I shave the tail lights do something custom wouldnt that change the vehicles identity. Also "various parts" could include an upgrade to an 8.8 and a 302?
any insight would be great. thanks
