Superdannn20
What's going on everyone. As the title states I'm new to the forum and to the Mazda pickup life and I am searching for guidance to head down the right path. I just bought a 96' B2300 5 SPD. I am planning on doing a few things to the truck to make it last and also make it "cool" and I could use some guidance.
1. Truck was owned by the same guy since 97' and he bought it off an older gentleman who only put 20k on it. The truck has had the engine rebuilt a few years back and other than that it's just had regular maintenance. The previous owner had the rebuild done professionally and had the receipt along with others.
2. The truck drove pretty good. There is some play in the steering wheel and the rotors are probably warped as there is some shake when I brake. There is a minor oil leak, some surface rust on the frame, and the odometer stopped working at 126K. Other than that the truck is pretty good.
I want to drop it a few inches, change the wheels, replace the headlights, suspension pieces, rotors, brakes, fix the A/C, timing belt, water pump and anything else that may be wrong with it.
My questions for everyone are:
A. What parts should I use when replacing everything?
B. What should I look out for when owning this truck?
Just looking for advice on what to look for and what to do. I am no mechanic by any means. I plan to use this truck as a way to learn how to wrench. A buddy of mine is going to help me along the way.
I appreciate your time and I am looking forward to your help.
Thanks
Thanks
