Phil in Lowgap
- Feb 21, 2011
- undetermined
- Automatic
Hi I do not own a Ford Ranger but I an using ranger parts.
I started building a motor trike using a Suzuki shaft driven motorcycle and a Ranger rear end. It turned out to not work very well because the Suzuki driveshaft rotates counter clockwise and the ranger pinion shaft rotates clockwise. The Suzuki has been modified and is committed to this build.
It was suggested that I use a Ranger front differential because it normally rotates opposite the direction from the rear differential. Can anyone on this forum confirm if this is true?
Do both front and rear driveshafts rotate clockwise as you are facing from the front of the truck?
