89ranger520
- Jan 10, 2010
does any on know if the computers and wiring from a 1996 ford ranger is compatible with a 1989 ranger? any info is appreciated thanks
Not sure how, unless both are 4.0liters and was the engine swaped in?
Welcome!
Ok now that I understand you want to swap a 4.0 from a '96 to a '89. well you came to the right place, I'm not the best educated when it comes to engine swaps cause i've never done it. But there is tons of info in the tech library check out this link from the library: http://www.therangerstation.com/tech_library/4L_Conversion.html
If it dosn't answer your question there are a couple more links for it there just check'em out. If not scroll down more on the forums and there is a 4.0 liter area to ask questions in. Hope this all helps out good luck with the swap, and welcome to the the site.
