New Wheels and Tires!!!
Gary101386
Oswego IL
got a great deal on some 285/75/16's (33's) just had to find me a set of 16's to put them on...
found a local scrap yard that had the wheels i was searching for.
99 explorer/ranger wheels.
old: 30x9.5x15's
new: 285/75/16's
probably going to have to crank my T-Bars and block the rear just a bit. I get minor running full lock to lock, and if im gonna crank the front then i gotta do the same to the back...
but i absolutely LOVE IT, looks so much better!
If I am not mistaken Tbars (torsion bars) are only on 98+newer Rangers.
Maybe just cut the fenders and be done with it.
I was going to say the same thing. I would say either block the rear or just do something cheap and simple like a body lift to clear those tires.
Did you trade your doors for the wheels?
It's TTB, it does not have torsion bars.
You should be able to run a 1" to 2" spacer under the coil spring and it still be alignable. I run a 1" spacer under mine.
Please note, any change in ride height on TTB, no matter how miner, will REQUIRE an alignment.
Also, does it have the high-rider package?
im not rubbing on the fenders, its just barely touching the sway bar where it bolts to the frame.
yeah i plan on blocking the rear and spacing the front....
haha no, the truck has no AC so i ripped the doors off. they go back on in less than 5 mins...
Lol crank tbars.
Suspension lift ftw.
im in the process of buying a house and have alot of other things i want/need to do on my plate... big costly items are going to have to wait...
thanks! Where'd you get you spacers from? 1" should do it!
yes it is the high rider
I am a little embarrassed to admit it, but I just used a wheel bearings and races that I laid under the spring perch. The stud was long enough to get the nut on with the spacer under the perch.
I do not know what they are from, I just browsed the bearing isle at my local Advance until I found bearings and races that where the correct size. I think it was less than $10.00 for the pair.
Sorry about the delay on this.
The bearing/race assembly is laying on it's side between the axle beam and lower spring retainer/perch.
if your truck is the one that is your avatar id like to see some pics of it:D
