lithicman
- Sep 12, 2015
Greetings folks - Newbie/lurker here. I've learned an enormous amount on this forum, and I thank you for sharing your collective wisdom. I hope that I can learn even more with this particular issue.
1994 Ford Ranger, 2.3L 4cyl - Replaced transmission (with a rebuilt one-M5OD), master cyl, slave cyl, clutch (pressure plate, clutch plate), pilot bearing and had flywheel machined. I also replaced the starter motor/solenoid. Bench bled master, then gravity bled master/slave after install, putting approximately 2.5 reservoirs full of fluid through the system (never letting reservoir run dry). Good clutch pedal pressure. This project took far longer than anticipated, so the battery was a little low (approx 11v) and it started without issue.
I took it for a test drive last night. I was going to take an approx 2 mile loop around the neighborhood. Everything seemed ok (at least in my mind the following are likely typical following such a job:
1. clutch engaged very close to floor;
2. There may have been a slight odor;
3. It was challenging at times to get the truck into gear
The following I am not sure are likely:
1. There was a whirring noise from the clutch area;
2. I am not sure if the car was ever-so-slightly pulling with clutch depressed and in gear).
After 1.5 miles, I made a right at a stop light, accelerated and after 2 blocks it felt (as I recall) like the truck was stalling. It remained in gear and I was rolling sluggishly. I pushed in the clutch, turned the key to start, and it would not start. I then got it into gear (3rd?) and tried to start by releasing the clutch, and it would not start (I was moving very slowly by then). I pulled to the side of the road, and tried starting it several times. There was that whirring noise, and I also heard the starter spinning. The truck would not start.
Dejected, I walked home and began a long vigil of pondering.
Any assistance is greatly appreciated.
Thanks!
Thanks!
