I picked up a coolant system test and refill kit for the Escape and a R134A A/C Manifold gauge set for the 2011 since the A/C seems to fall on it's face when in traffic and it's pretty hot out.
Since there was a possibility that I would need to pull the water pump on the Escape and the timing belt as to be at least partially removed to do the job, I ordered this kit. I ended up not need ing it but I now have it for the future, when the timing belt needs changed.
While I was there, I also finally ordered the timing kit for the 4.0 SOHC. Not the best time financially, but I've been wanting to get it for a while and sooner or later, I'm going to need it.
My brother got the kit to do timing on Duratec engines, simple really... Also ended up getting him a 3/4" air impact for the crank bolt (he farms so not bad to have around anyway) but I ended up making an "inertia" socket by welding a cheap socket in a big heavy impact socket, my "high torque" bauer 1/2" impact got it right out with that... Also while I had the welder out I welded a big nut with 1 1/8" hex to a 1/2" drive 2" long extension so I can assist an impact if needed (we had plans B, C and D covered). While at Harbor Freight getting that impact I grabbed some more 1/2" impact extensions since I was wasting one...
I bought a huge 100 - 600 lbs-ft 3/4" drive torque wrench along with a big six point impact socket set. Apparently, Timberen recommends checking the torque on their hinge bolt once a year, 450 lbs-ft. Nothing I have will go that high and I would probably be hanging off of what I have to get even close.
I also bought a new soldering gun since the iron I have seems to have pooped itself.
I talked myself into one of the Titanium welding tables from Harbor Freight, the thing's a beast really, should be pretty nifty after I get some of the gross stinky oil off of it... I mean a fab table with clamps for $150? not bad... assuming I start using it appropriately... I'll try...
Event Coverage
TRS Merch
