You really wanted that spring in there.
Did you try to phone a friend?
I want to say I've run across this situation myself. Not sure what I did.
Picked this up today...
New tools you've bought recently? New tools you've bought recently?
Yes, it's a Harbor Freight, but it does pretty much everything (MIG, Stick, TIG or flux-core . Son-in-law got it from a friend used once. $250.
Now all I have to do is learn how to use it :unsure:
That's a problem that I wish that I had . . .
I'm starting to seriously want a welder.
Nice score! (y)
View attachment 127172 View attachment 127173
Best way to learn is to take a course at a local college.
If you know a welder then offer some money for training
Watch YouTube videos.
PPE.
Lots of light on the subject. Sometimes I use a couple 500 watt lights on either side of what I'm welding.
Practice, practice, practice.
I have the big brother to that the 200 and it welds real nice, used it on flux core for several years before getting a bottle and it still welded decent for flux core... I have the spool gun and have done some TIG with it and no real complaints other than aluminum is a pain with the spool gun but I think that's just how it is... for learning there's some good youtube videos to help out, I think it's the weld.com ones that I like the most, the main guy that does them is very good at explaining things and what works and what doesn't... if my internet wasn't being stupid I'd look for a couple...
Thanks a lot for the response. That makes me feel a little bit better about the HF designation and I will watch the Tube vids. (y)
Definitely learn all you can about what’s a good weld and what’s not.
Personally I think Tig and Stick are best types of welding for a hobbyist to learn because they are the most versatile.
MiG and Flux core are better when you are welding a lot of the same material all the time because the changeover for different materials is a lot more work.
that looks exactly like my 35+ year old Sears jack, 'cept mine's green.
I use the squeaky wheels to annoy the neighbors.
It is a 35+ year old Sears jack. Made in Japan. Can't just throw out a good tool.
I bought some new pin punches after I broke a couple and a low profile ratchet so I can work on the rear differential of the Escape.
Although I don't disagree now that I've dabbled with TIG it's more persnickety than I'd prefer for day to day use, if dealing only with stainless sure but out of position is still not fun... (my only TIG experience is scratch start DC with the Titanium 200, if I had an AC/DC machine with a pedal I would probably have a different opinion). Stick has it's place for sure definitely on heavy stuff... MIG is great for general welds where you don't want to deal with cleanup afterward but can deal with a little less penetration. Flux core is somewhat of an inbetween, you get all the cleanup of stick but with the convenience of a glue gun... I actually bought a discount Titanium 125 to use for a camp welder and we used it in camp a few weeks ago and it was great... my MIG bottle is about done and I had a quick welding project the other night and just plugged that in to save my gas for a specific project probably next weekend...
I have more welders than I'd like to admit (ok, 6 just at my house, another at my brothers, not including the torch set...), I'll use the best suited for the job or what I'm in the mood for, a couple weeks ago I had to use stick for a project because it was welding the inner support to the inside of a tractor air cleaner housing that was recessed about 6" so no way to get a MIG gun in there, had to bend the last 2" of rod to weld on the side and use 3 rods to just use the tip... Anything 1/4" or more I'll generally go with stick just for the penetration but if I could only pick one process for general use around the house and farm I'd probably pick flux core just takes cleanup between passes...
My interwebs are working better this morning but the guy I like to watch for welding tips is definitely weld.com, they have several to do/not to do type videos to show how things should and shouldn't work for those that are visual learners...
Oh, and best way to learn is practice, then practice some more, screw up, get frustrated, figure out what you did wrong then try again... A tip if you are going to stick weld my choice for a general use rod is 6011 for rough general use and 7018 for prettier stuff, supposedly 6013 is easier to use but has less penetration...
Another resource that slipped my mind...
Look online for the manuals for apprentice welders. Had a young friend give me his and I'm learning a lot. The book I've read was for stick, and I learned a lot about the rod numbering and uses along with other stuff. I wish I had got these before welding on my lift, I think I would have been better. Tho I'm not worried about my welds holding up. I've been hobby welding for 40 years. I took welding in high school and also a night school course, but those were decades ago. I forgot lots...
What I like about TIG is that you can use the same gas for any material and just need to gaba different filler rod. Unlike MiG where you need to change the spool, feed the wire through the liner, and change the gas
For tac welds you don’t even need a filler material, just melt the edges together.
Plus, no slag to drip on your head when welding out of position.
It is more picky with keeping thr tip clean though, so maybe an issue with dirty/ painted/ oily metal.
I imagine a high frequency start machine would help a LOT, scratch start out of position was a pain in the tookus... welding up the cracks in a commercial style sink for my brother for a couple hours I ended up grinding up almost a whole stick of tungsten... it's still a couple inches long...
Looking at my welds with the flux core from the other day, they actually turned out great for following the settings on the lid... probably a little hot but not bad... I'll probably take pics tomorrow after the paint dries...
Today I went to another auction (if you're paying attention, it happens...) and couldn't help grabbing a few tool bags... got some sockets to fill up some empty slots in the shop box, oddly enough I ended up with like 10 spare 10mm sockets and a handful of 9/16" sockets... there's even some medium length sockets which I had none of... that's about as far as I've dug through, that bag was garbage so I wanted to get it out of the way... The rest is just random stuff like squares and screwdrivers and such...
My tig machine is an old transformer unit. Cheap hobby grade job by miller, EX TIG or something.
Has a pedal and gas valve built in. Gotta imagine it would be a pita without the pedal control, at least on light gauge stuff.
I would like a newer inverter unit with square wave AC, and some more adjustability.
