New to the station
bandit31985
Vermont
Just wanted to say hi to everyone and hopefully you guys can help me with out with a few questions and concerns. I have a 2005 ranger xlt auto with 44000 miles on it, owned it since 17 miles. I love to go wheeling with it but im always worried its not the right rig. I mean its STOCK with all terrain tires, no skid plate and the only maintenance I've done to it is change the oil, oil filter and air filter whenever every 3 months or 3000 miles. Sometimes the transmission seams to clunk into gear, maybe i just need to change the fluid?
So I was wondering if maybe you guys could shed some light on weather its a good 4x4 or what? maybe tell me what makes it good and what i can do to improve on some of its weak points if any?
:icon_cheers:
Jesse
Welcome :beer:
Rangers are excellent wheelers, but certainly everything has at least a couple weaknesses...
Are you finding yourself getting stuck often? not being able to maintain traction?
There are plenty of options available you can do to your truck to improve it's offroad performance, although the type of wheeling you're interested in (mud/rocks/sand/old logging/mining/powerline roads, deserts/forests/mountains/etc.) could determine whether or not it's worth seeking out an earlier model Ranger (or Bronco II or Explorer) as a candidate for a wheeling build.
I would say have a look around the site here and see what everyone else is doing, then you can get a better idea if you want to keep your truck, or work on fixing up something else to go offroad with (check out the "Show Off" and "RBVs under construction" sections). :icon_thumby:
Thanks for the welcome guys. 4x4 junkie I mostly go on trails or old logging roads, I haven't had any real problems with traction or getting stuck but i also haven't really done any hardcore wheeling. I dont dare go in much mud because i dont have enough confidence in my truck. Everyone on the forum seams to have older trucks, I haven't seen any builds with newer models why is this? I dont know what to do, i have thought about trying to find an older model and keep my truck also but dont know what to look for, also debating on a jeep. So whats your opinions guys, new old ranger or jeep? what years/models are good
Im sure lots of us have older truck for a couple reasons. first some of us beat the crap out of the trucks so old trucks that arn't worth lots are good for that.
Secondly Some of us are also not willing to spend money on new trucks so we buy older trucks.
And o/ welcome.
We have old trucks because they are cheap and be abuse them. You could do so little improvements. First get a good tranny cooler. Maybe some more aggressive tires. Tires wont help if it has an open diff so get a lunch-box locker. Some good hooks and tow strap so your buddy can get you out of the mud. Just start small and have fun.
mudding
get a bronc and build it then ride the hell out of it o by way welcome
Ok why do you say get a tranny cooler first? I have a buddy with wheels and good tires that i think are 33" off of his old explorer, will they work for me? Yut mine defiantly has an open diff, so i checked out the tech library and read up on lockers and it seams they aren't good in snow. We get allot of snow here in vermont, is there any better options for me other than the lunch-box or is that about it? I think i have a 8.8 inch axle but not sure? One more question, if i change to bigger tires to i have to change gearing or anything?
chances are if you have an open dif yuo have 3.73 gears. Being an auto biger tires might make it really boring to drive and be really hard on it. But 33's arent that big so they would probably be fine, but you wouldn't want to go much larger. Just crank yout t bars and gat a ada leaf for the back and you could probably fit those tires of the explorer. The trans cooler is for the bigger tires. If you go biger with out a trans cooler your going to cook your tans, its only a matter of time.:headbang: and welcom! I'm really new around here to! it's a great site:icon_thumby:
keep that nice truck for a daily drive and get an older ranger to build up, its cheaper and easier to fabricate stuff on it, i dont have any yet, but for what ive seen here, thats the best advice i could give.
yours is pretty capable, just take it slow n easy and im sure u will pass any mud hole.
i would say welcome, but ur not that new lol!!
nah..what the hell.. welcome to TRS!!
There are quite a few here with newer-model trucks built up for harder core wheeling, but you are correct that older truck builds tend to be more numerous.
Probably the biggest reason for this is because of the more offroad-friendly and modifiable TTB (Twin-Traction-Beam) suspension the '97 & down trucks have. Like was said, it's much easier (and cheaper) to build this setup into a highly capable 4-wheeler (much like with old solid-axle suspensions).
Then the fact hard offroad use is bound to cause some dents and scrapes... Having an older truck that already has a couple dings and/or less-than-stellar paint, it won't be as much of a concern if you should happen to rub up against a rock or tree (or a mountain lol).
As for the Jeep... About the only thing good I can really say about them is the fact you can pretty much literally go down to the store, buy anything you can think of for it, bolt it on & go. Pretty much everything conceivable is made for it. The Ranger (or anything else in the RBV family) will generally require you to build some things for it yourself (good durable winch bumpers and rock sliders, for example), for which you'll need a good welding setup.
I don't consider this a bad thing however, because you can then design the item to exactly fit your own needs, rather than that of a mass consumer base. You'll get to save bucketloads of money building it yourself (the price of a good bumper/tire carrier setup for a Jeep is likely to send you spiraling into sticker shock), and lastly, you get to brag "I made it myself!" :icon_thumby:
IMO, I think the RBV's driveline hardware is better than that of the Jeep too (specifically '90-'97 RBVs with the 4.0L V6). Both axles are stronger, the transfer case comes factory with a fixed yoke on the rear, the engines tend to get much better mileage yet have similar power, and so on (just look at how many people are snapping up Explorer 8.8" axles to swap into their Jeeps these days lol).
The only real exception to this would probably be the A4LD automatic trans used in RBVs through '94. The M5OD stickshift is dirt-reliable however, at least as long as it has fluid in it (the factory rubber shift rail plugs sometimes tend to leak a bit on them... an easy fix).
Anyway, hope that helps. I'd try a low-buck approach at first and see how you like it. Get yourself a 3" body lift and crank up the torsion bars a bit which will allow you to fit some 33" mud tires, then throw a couple "lunchbox" lockers in each end (lockers such as the Aussie Locker or Lockright locker that drop in place of your differential's spider gears). These are usually less than $400 (sometimes less than $300).
It's true these lockers will change the truck's behavior somewhat in the snow, but the vast majority of people quickly get used to it and have no further problems with it.
If you have 4.10 gears stock, you shouldn't need to change gears for 33s. If you have 3.73s, this is a borderline case... a gear swap will bring an improvement, but it's likely to be tolerable for the most part. Like suggested, get an external cooler if you have the auto transmission.
I would look at the '94 with the 4" lift first. Find out what motor it has in it and see what it has for a lift. Then I would check out that '92 for the simple fact that it is a regular cab short box 4x4, which makes for a good shorter length wheelbase for wheeling.
Oh and WELCOME! you can get info on anything you want here. Just have to learn who to listen to:headbang:
