DroidTN
- Nov 12, 2013
- Automatic
Hey guys and gals. This is my maiden post here. I just traded an old Passat for a great 1994 Ford Ranger. It is in excellent shape from what I can tell. It's a V6, not sure which V6 though. It has 31's with a 3" inch lift. I really like to "know" my vehicles, can you give me some tips to get acquainted with my Ranger? I am by no means a mechanic, but I am learning. I just want to know the truck inside and out and when something does go wrong, be able to identify it and fix it. So..any routines to go through it, things to look out for specific to a '94 Ranger. Can you recommend any repair manuals? It has about 158k miles.
Things that were done by the previous owner: new water pump, thermostat, radiator, fan blade, fan clutch, battery terminals, new spark plugs and wires, new heater core.
Things I want to do: 4 wheel drive doesn't work or I should say the 4 wheel drive/low button doesn't work, it doesn't light up. Also AC doesn't work, although that isn't a big deal, at least not for 6 months. Also the ABS light is on, previous owner said it was some sensor in the dash. And the needle indicating what gear you are in doesn't work, it just stays at Park.
Thanks so much!!
Andrew
Yes it is snowing today!!!
Thanks so much!!
Andrew
