DocLips
I just picked up an 88 BII with a 302/c4 swap already done. As of right now it doesn't run due to sitting in a field for three years. Most of the work was done with JamesDuff or advance adaptor parts. The 302 was from an 87 Bronco and has full MSD blaster 2 ignition, weiand intake(unsure of which yet) and a speed demon 650cfm carb. It has a 3in body lift and 2in susp. lift as well. I am thinking about converting it to 2wd and lowering for street/strip use once I get it running again. Is there a conversion parts list for 4x4 to 2x4 somewhere? I've done some light searching and only found 4x4 to 2x4 parts numbers and lists.
