New to Bronco II's but not RBV's
WNY964x4
ASE Master Certified
Firefighter
ASE Certified Tech
East Pembroke , NY
ok all you Bronco II guys , i am fairly new to the Bronco II scene and have a question for ya.
The BII i am getting is a 1990 2WD model , now i want to turn it into my mud truck and was wondering if my memory served me right in that all BII's , both 2 and 4WD use the same front suspension , if i am wrong , please correct me.
Thank You all for any and all help
Engine cross-member is the same, IIRC the passenger beam bracket needs to be changed and that's it.
and the transfer case too right the 2wd have a dummies case right
got the info from AllanD , and he said just the bracket for the passenger side beam needs to be changed , and this one has a true 2WD trans (Late 90 M5OD)
Welcome.
Good luck with the 4x4 swap, it's easy. :icon_thumby:
welcome to the world of expensive windows:thefinger:
welcome sir,, and that b2 4x4 swap will be friggin cake compared to a ranger 4x4 swap
as a Note, if anyone ever comes across a Late 1990 2wd Bronco2 with an
AUTO TRANS without the dummy T-case I'm lookin for that adapter piece that goes into the tailshaft of a 2wd A4LD and allows the 2wd trans to be used with a four bolt flange driveshaft.
I just need that adapter piece.
I've got one for a Mazda trans but they are a different (larger) spline than the A4LD.
AD
