- Aug 17, 2007
- central ohio
- 2.5 (4 Cylinder)
- Automatic
- Tire Size
- 235/70/16
- My credo
- the grey-t escape
...yes, i know there is a tire/wheel section, but thought i might get more veiws/opinions here, im considering going to a different tire/wheel this spring, wanting the wheels to be the black "D" window rims, 8" with 4" backspacing. (so the load will be centered on the bearings, not offset) tire size im considering is either 255/70's or 31-10.50's. stock is 235/75. the 255's would be the same height, just a inch wider, the 31's would be both a little taller and wider than stock. would i lose much in performance/milage with either size change? is the 4" backspacing going to work as far as clearances when turning? (stock height, no lift) my truck is a '93 4x4 supercab, plenty of wheel-well room as far as the eye can see, 265's were a option. i have 3.73 gears. i mostly run empty but do sometimes pull a 6x10 enclosed v-nose trailer. id love to run classic cragar s/s mags, but it would look odd leaving the front centers off for the lockout hubs.
heres the rims im considering: -> http://www.summitracing.com/parts/clm-7015812/overview/
