New thread for my low speed RPM issues
That's great that you got your Ranger running fixed. You will need to check your ABS codes. The most common problem I've seen with the Ranger ABS is the speed senor that's mounted it the rear end. If that's your Rangers problem it will be a cheap easy fix.
