camelman
- Sep 29, 2014
I have another thread that I started with timing belt questions and moved on to engine operation questions, but figured I should switch to an engine-specific thread to make it easier to follow and search. So...
I replaced my timing belt, spark plugs and plug wires on a 1997 5-speed 2.3 with 175,000 miles on it a couple weeks ago. After doing that, my low RPM performance got bad. I must carry higher revs than before to keep the engine running smooth or else it bucks. I do not have a tach, but this happens if I dip below 10MPH in second, 20 MPH in third or 30 MPH in fourth. I remember the engine pulling smoothly from 0MPH in second, and 10 MPH in third before, so something is up. I did the following to fix it:
1) Replace the IAC
2) Clean the MAF
3) Replace the valve cover gasket and clean the area
4) I checked all electrical connections, and everything seems to be in good shape
~ Replacing the IAC made the engine run more smoothly, but did not fix the bucking at low RPM. The old IAC plunger would stick, so I know it was not working well.
~ Cleaning the MAF seemed to make no difference.
~ I replaced the valve cover gasket because it was so leaky I thought it could be bad for the wires... and it was dripping oil all over the engine.
The engine pulls smoothly and with plenty of power once it is above the "bucking" RPM. Fuel mileage is in the mid 20s, and I have not noticed any pinging. I plan on doing the following:
1) Measure resistance across the TPS to see if it is smooth throughout operation range
2) Clean the EGR
3) Look for leaks in the intake tubing
4) Look for any vacuum leaks
5) ???????What should I check on the DPFE???????
Any other thoughts? Has anyone had success in fixing an issue like this? My check engine light is not flashing, so I have not checked for trouble codes...nor do I have the equipment to check for trouble codes.
Thanks,
Camelman
1) Replace the IAC
2) Clean the MAF
2) Clean the EGR
Thanks,
Camelman
