New shocks for 2"~2.5" lift for Bronco II?
outatime88
California
Total Drop
3/4
I'm going to be lifting my '85 Bronco II's stock suspension to 2.5" in the front and 2" in the rear. Now I've read that you should replace stock shocks for anything over 2". Will I need new shocks even though I'm only at 2.5? Also I looked around and can't figure out what collapse and extended length to get. I went on summit and put in my lift and it gives me shocks that go from 10"-16" and another that goes from 15"-26"...I mean how could both of those work? I don't understand. Or maybe should I just get shock extender just for the front?
Bought these for the ranger a while ago for my 2" lift. They were less than $50 each. They are for a 2" lift.
Do you know the model number? RS5000 seems to just be the series.
Another question. I was going to order new camber bushing from the Bronco graveyard website but it seems as though they are backordered. The bushing look adjustable and say they go up to 2 3/4 degrees.
http://shop.broncograveyard.com/Dana-28-Adjustable-Alignment-Bushings-Pair/productinfo/93530/#
Now on rockauto I saw a similar bushing that is full rotational and up to 2 3/4 degrees. This is the same thing right? This would work?
I also saw this Moog one which seems to look different but I guess still works? It also seems to be an extremely popular item.
Yes RS5000 but they come in various lengths for stock or lifted vehicles. No clue about bushings.
