Melt
sup guys, ive been into hondas pretty much as long as ive been driving (almost 8 years) and finally decided due to a few things i need to do in the coming year that a truck will better suit my needs.
I like rangers / b2300's because they are reasonable priced and look good.
Anyways, heres what im looking at currently
97 b2300 xcab 2.3l 4cyl 5spd 2wd (gas mileage is priority #1)
138k miles, new clutch, ac, heat, bedliner,
138,600 miles
homie wants $2850 obo for it .... blue book in "good" condition is $3300 on kbb
anyways a few questions
1) what sorts of problems should i look for in general
2) im under the impression that these have a timing belt. Being a honda guy all my life, the timing belts on those are changed every 90k and you have to pull out the engine to do it ... how often should they be changed on these and how labor intensive is it?
3) how easy is it to acquire parts to lower it and what does it generally cost. From what i understand these suck to lower in comparison to s10s due to suspension design, but no way im getting an s10 cause the 4cyl is weak as hell
4) do they make aftermarket clear lenses / grills for the front? Never been a huge fan of the 97 older mazda front end, but this truck is a very good deal because finding an xcab is hard around here, and finding one with a/c harder.
5) if not how hard is it and what is required to convert to a 98+ front ... ive seen pictures of some other dudes b3000 that put an 05 ranger front on it.
6) oh and how much of a pain in the ass is it to wire up an amp and subs in the back of the xcab ... im assuming theres some sort of removable grommet in the floorboard by the firewall like theres been in every honda ive ever had ... ive seen rangers with systems so it cant be that bad
if anyone has other suggestions let me know, and hopefully im not being too noobish to the board. Im also considering getting a nissan frontier cause those arent bad either ... but not really a s10 or tacoma guy cause like i said earlier the s10 is gutless, and the tacomas are generally out of my price range.
and yes if you are on ranger-forums youll see this same post over there ... still trying to figure out which forum i like
138,600 miles
