New owner of an 87 Ranger
TABrinn
Corpus Christi
TX - USA
Vehicle
Drive
2WD
2.9L
Stock.
Total Drop
Maybe 3/4 eventually
87 Ranger XLT ext cab, 2.9 v6, auto. $750
Hunting down a new steering coupler because, the wheel is spinning. The coupler in there now is definitely new but the shaft is about an inch too short to make up. I'm sure electrical gremlins abound. PO said it was parked 4+ years ago due to fuel pump issue. It's probably an electrical fault.
If it passes compression check and holds oil pressure, I'll daily drive as commuter while I build a destroyed 4.0 ohv t5 combo. Rev-happy sporty build like the euro Cologne builds in The Capris and Scorpio, etc. Maybe see if I cam import one of the Cosworth 2.9s! Make a proper sport truck. Quick, fun, handling, and balance.
If I get frustrated, I know these early 1st gen Rangers go for about $3k, even for a basket case.
Anyone ever built a destroyed 4.0 ohv or know of one?
Destroked 4.0 ohv or SOHC... not destroyed. Darned fat fingers strike again!
Decoded the Axle (F7) as a 4.10 LSD! Need to verify but that has somewhat solidified my plan to keep the 2.9, swap in my T5 in place of the automatic, and update the electronics and electrical system. Need to find a Mustang 4.0 sohc manual bell housing so I can swap in my T5 in place of the slushbox a4ld. The vision is more of a Canyon carving street truck than a drag truck or trail rig.
Going to just rebuild the 2.9, clean up the heads after getting them checked for cracks, and run Euro cam from Piper or Kent (or similar usdm spec), upsized 4.0 TB port-matched, gasket matching the upper to lower intake, modern Injectors, distributor delete w/ LS Coils mounted off firewall, and run it all on Megasquirt 3.
Guess I need to get a build thread started.
