overheadvalve
- Dec 31, 2012
- Automatic
Just found this fantastic site and am now a proud member. I have searched and searched and am still confused. Here's the story:
2000 Ford Ranger 3.0 Flex, Auto, 4X4, extended cab. 86K miles. 4 wheel drive working on and off even though light says 4 high(no blinking ever). I did the hub mod where you push in with your finger to confirm the hubs are locked. I will order manual hub kit next week but the mod didnt help.
I purchased a Cardon remanufactured transfer case motor and installed it yesterday. Now I get the four blink, sometimes six blink, sometimes the light stays on and says 4 High, sometimes goes out, lots of clicks, then sometimes no clicks. Disconected battery, checked all fuses etc. I took the motor off then couldnt get it back on without taking off the lower rubber damper looking part to tip the motor down far enough to go back on the shaft. Still no 4 wheel drive. Im worse off than before when it would occasionally engage.
I decided with my limited diagnostic skills that the transfer case control module needs replaced so I called local dealer and was quoted $338.96 for a Body Control Module part #YL5Z14B205EA. So.....my questions to the experts are:
What am I doing wrong?
Why was the transfer case shaft not lining up with the new motor, kind of between 2 high and four high?
Is the above part the Transfer Case Control Module or something different?
Where is this Transfer Case Control Module?
I guess thats all I can think of for now. Im trying to get this fixed so my son can get back to college next week. Thanks to all for any help.
