kevm14
- Jan 24, 2008
- Automatic
As a new homeowner I had been thinking about getting something with a bed but wasn't seriously looking. When a co-worker mentioned he was thinking about selling his 91 Ranger, the stars aligned, and we made the transaction.
It's a 91 XLT 2wd long bed with the A4LD. It has 71k (yes, 71k) and the body seems to be in pretty good shape. I haven't seen any rust and the clearcoat is also in decent shape. Even has a cap on it, which is handy sometimes. I've never owned a truck before so this is something new and different.
I was disappointed to find out the EPA ratings of the automatic are only 21/23 while the 5-speed received 24/29. That is a HUGE difference. The only time I've seen a difference that big was when the automatic was a 3-speed without overdrive. That said, I was expecting to get basically at least 20mpg in just about any condition except short trips. Well I made a drive on the highway to pick up some furniture and that returned a calculated 17.5mpg. There are definitely some hills on this drive but I still expected 3mpg better at the least. I will gather some more data points but so far I am disappointed.
The engine actually seems to run pretty well. No pinging. I'm not really sure what to do (I want to take it easy with throwing parts at it as this is technically a beater). I have already replaced the air filter but I was considering cleaning the MAF (need to pick up some tamper proof torx sockets first) and replacing the O2 sensor. I do own a scantool but I only have the GM cable (my other cars are GMs). From my experience with GMs, the best O2 sensor to run is the OEM one. Is this the case with Fords?
Is there anything else I should look at? It needs a cat-back exhaust which I will actually be doing today. While I have the I-pipe off, I will examine the cat and try to see if it's clogged. But the truck runs well enough that I doubt it is.
Also, there is a coolant leak. It is either the lower hose or the water pump. Are the water pumps trouble spots on these or should I just throw a hose on it and hope for the best?
The gas gauge is stuck on E and at some point I'll drop the tank and replace the flooded float if I can locate a new one somewhere.
The coolant temp gauge also barely comes up to the first line in the NORMAL zone. Is this normal? Should I replace the sender? The heat works really well. Perhaps the computer sensor for ECT as well?
It has A/C but it doesn't work. I have some experience with that so I might convert to 134a in the summer. Then again, I'm not sure it has enough power to run the A/C and drive at the same time.
I've already replaced the floppy driver's side mirror with a Dorman chinese replacement. That cost $9.50 plus $7 shipping via Rockauto.com (955225). I was about to fix it myself but I had to hack the old one to pieces to get it off the truck (stuck torx bolt). Besides, why mess around for $16.50?
The dome light was missing and I found out why. It wouldn't go out. I replaced the passenger side switch and it works great now. That was easy.
Since I have finished complaining I thought I'd mention what has impressed me so far. I was expecting a very junky, clunky feeling truck. Maybe it's the low mileage but I am really quite impressed with how tight and solid overall this truck feels to drive. The turning radius is great. Hell, even the factory audio surprised me. I think I am going to like this truck but that mileage needs to improve a bit. 100hp isn't a lot.
Here are a few pictures.
What is this all about?
What the hell is this thing?
